Incorrect report of monitor refresh rate by games
Recently I noted that Witcher3 (Proton-5.9-GE-5-ST) is limiting to max 60 fps whereas before it was 75, which is my monitor refresh rate.
I use xrand for the configuration and it shows the screen is at 75, so I wonder if rxanrd is incorrectly reporting, or something broke in some recent update (5.6.19-2-MANJARO().
Screen 0: minimum 320 x 200, current 4480 x 1440, maximum 16384 x 16384
DisplayPort-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
   2560x1440     59.95 +  74.97*
   1920x1200     59.95
   1920x1080     60.00    50.00    59.94
   1600x1200     59.95
   1280x1440     59.91
   1680x1050     59.95
   1280x1024     75.02    60.02
   1440x900      59.89
   1280x960      60.00
   1280x800      59.95
   1280x720      60.00    50.00    59.94
   1024x768      75.03    70.07    60.00
   832x624       74.55
   800x600       72.19    75.00    60.32    56.25
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    72.81    66.67    60.00    59.94
   720x400       70.08
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 connected 1920x1080+2560+0 (normal left inverted right x axis y axis) 527mm x 296mm
   1920x1080     60.00*+  50.00    59.94
   1680x1050     59.88
   1440x900      74.98    59.90
   1280x800      60.00
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       60.00    59.94
   720x400       70.08
Have you tried switching between RGB and YUV display modes?
Many thanks! I looked into it and it seems to modify EDID with some non-official tools. This is a machine I also use for work, so I am not risking.
Another thing I’ve been checking is that maybe it was my mind playing triks. I am sure to have set it to 75 at some point, but googling it seems this is not possible :man_shrugging:, also checked on Windows. So I’ll assume it’s me.
Oddly enough I find the image to be more fluid with capped 60fps than uncapped, with runs at 90. Specially on Windows, even run a test with vrrtest and it seems freesync on Linux is not as good as in Windows. Won’t change for that, but I wonder if it’s me or is real.
