Next time I reboot, I’ll take a look at the bios for boot GPU options.
Here is the output of lspci -v:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Flags: fast devsel, NUMA node 0
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Flags: fast devsel, IRQ 30, NUMA node 0
Capabilities: [40] Secure device <?>
Capabilities: [64] MSI: Enable+ Count=1/4 Maskable- 64bit+
Capabilities: [74] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [c8] Vendor Specific Information: Len=18 <?>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 32, NUMA node 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Root Port (Slot-), MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
Capabilities: [c8] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [150] Advanced Error Reporting
Capabilities: [270] #19
Capabilities: [2a0] Access Control Services
Capabilities: [400] #25
Capabilities: [410] #26
Capabilities: [440] #27
Kernel driver in use: pcieport
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 33, NUMA node 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: fb200000-fb2fffff
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Subsystem: Micro-Star International Co., Ltd. [MSI] FCH SMBus Controller
Flags: 66MHz, medium devsel, NUMA node 0
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Subsystem: Micro-Star International Co., Ltd. [MSI] FCH LPC Bridge
Flags: bus master, 66MHz, medium devsel, latency 0, NUMA node 0
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 7
01:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Capabilities: [48] Vendor Specific Information: Len=08 <?>
Capabilities: [64] Express Endpoint, MSI 00
02:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
02:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller (prog-if 30 [XHCI])
Subsystem: Micro-Star International Co., Ltd. [MSI] Starship USB 3.0 Host Controller
Flags: bus master, fast devsel, latency 0, IRQ 68, NUMA node 0
Memory at fb200000 (64-bit, non-prefetchable) [size=1M]
Capabilities: [a0] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [c0] MSI-X: Enable+ Count=8 Masked-
Capabilities: [370] Transaction Processing Hints
Kernel driver in use: xhci_hcd
20:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Flags: fast devsel
20:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Flags: fast devsel, IRQ 29
20:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
20:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
20:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
20:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 34
Bus: primary=20, secondary=21, subordinate=21, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: c0300000-c03fffff
Prefetchable memory behind bridge: 00000000d0000000-00000000e01fffff
Capabilities: [58] Express Root Port (Slot+), MSI 00
Capabilities: [c0] Subsystem: Device 7c59:1462
Capabilities: [370] L1 PM Substates
Capabilities: [380] Downstream Port Containment
Capabilities: [3c4] #23
20:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
20:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
20:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
20:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 36
Bus: primary=20, secondary=22, subordinate=22, sec-latency=0
20:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
20:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 37
Bus: primary=20, secondary=23, subordinate=23, sec-latency=0
Memory behind bridge: c0000000-c02fffff
21:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon Pro WX 7100] (prog-if 00 [VGA controller])
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon Pro WX 7100]
Flags: bus master, fast devsel, latency 0, IRQ 175
Memory at d0000000 (64-bit, prefetchable) [size=256M]
Memory at e0000000 (64-bit, prefetchable) [size=2M]
I/O ports at 1000 [size=256]
Memory at c0300000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at c0340000 [disabled] [size=128K]
Capabilities: [58] Express Legacy Endpoint, MSI 00
Capabilities: [200] #15
Capabilities: [2b0] Address Translation Service (ATS)
Capabilities: [2c0] Page Request Interface (PRI)
Capabilities: [2d0] Process Address Space ID (PASID)
Capabilities: [320] Latency Tolerance Reporting
Capabilities: [328] Alternative Routing-ID Interpretation (ARI)
Kernel driver in use: vfio-pci
Kernel modules: amdgpu
21:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
Flags: bus master, fast devsel, latency 0, IRQ 174
Memory at c0360000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel modules: snd_hda_intel
22:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Flags: fast devsel
23:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Flags: fast devsel
23:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Flags: bus master, fast devsel, latency 0, IRQ 152
Memory at c0100000 (32-bit, non-prefetchable) [size=1M]
Memory at c0208000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [c0] MSI-X: Enable+ Count=2 Masked-
Kernel driver in use: ccp
Kernel modules: ccp
23:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 77
Memory at c0000000 (64-bit, non-prefetchable) [size=1M]
23:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] Starship/Matisse HD Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 172
Memory at c0200000 (32-bit, non-prefetchable) [size=32K]
Kernel driver in use: snd_hda_intel
40:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Flags: fast devsel
40:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Flags: fast devsel, IRQ 28
40:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
40:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 38
Bus: primary=40, secondary=41, subordinate=49, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: f8000000-f8cfffff
40:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
40:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
40:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 39
Bus: primary=40, secondary=4a, subordinate=4a, sec-latency=0
Memory behind bridge: f9100000-f91fffff
40:03.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 40
Bus: primary=40, secondary=4b, subordinate=4b, sec-latency=0
Memory behind bridge: f9000000-f90fffff
40:03.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 41
Bus: primary=40, secondary=4c, subordinate=4c, sec-latency=0
Memory behind bridge: f8f00000-f8ffffff
40:03.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 42
Bus: primary=40, secondary=4d, subordinate=4d, sec-latency=0
Memory behind bridge: f8e00000-f8efffff
40:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
40:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
40:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
40:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 44
Bus: primary=40, secondary=4e, subordinate=4e, sec-latency=0
40:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
40:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 46
Bus: primary=40, secondary=4f, subordinate=4f, sec-latency=0
41:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 57ad (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26
Bus: primary=41, secondary=42, subordinate=49, sec-latency=0
Capabilities: [58] Express Upstream Port, MSI 00
42:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 57a3 (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 47
Bus: primary=42, secondary=43, subordinate=43, sec-latency=0
Memory behind bridge: f8c00000-f8cfffff
Capabilities: [58] Express Downstream Port (Slot+), MSI 00
42:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 57a3 (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 48
Bus: primary=42, secondary=44, subordinate=44, sec-latency=0
Memory behind bridge: f8000000-f84fffff
42:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 57a3 (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 49
Bus: primary=42, secondary=45, subordinate=45, sec-latency=0
Memory behind bridge: f8b00000-f8bfffff
42:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 57a3 (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 50
Bus: primary=42, secondary=46, subordinate=46, sec-latency=0
Memory behind bridge: f8a00000-f8afffff
42:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 57a4 (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 51
Bus: primary=42, secondary=47, subordinate=47, sec-latency=0
Memory behind bridge: f8600000-f87fffff
Capabilities: [58] Express Downstream Port (Slot-), MSI 00
Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Device 1484
42:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 57a4 (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 53
Bus: primary=42, secondary=48, subordinate=48, sec-latency=0
Memory behind bridge: f8900000-f89fffff
42:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 57a4 (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 55
Bus: primary=42, secondary=49, subordinate=49, sec-latency=0
Memory behind bridge: f8800000-f88fffff
43:00.0 USB controller: ASMedia Technology Inc. Device 3242 (prog-if 30 [XHCI])
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 7c59
Flags: bus master, fast devsel, latency 0, IRQ 54
Memory at f8c00000 (64-bit, non-prefetchable) [size=32K]
Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [68] MSI-X: Enable+ Count=8 Masked-
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [c0] Subsystem: ASMedia Technology Inc. Device 0201
Capabilities: [100] Advanced Error Reporting
Capabilities: [200] #19
Capabilities: [300] Latency Tolerance Reporting
Capabilities: [400] L1 PM Substates
44:00.0 Ethernet controller: Aquantia Corp. AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] (rev 02)
Subsystem: Micro-Star International Co., Ltd. [MSI] AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion]
Flags: bus master, fast devsel, latency 0, IRQ 135
Memory at f8440000 (64-bit, non-prefetchable) [size=64K]
Memory at f8450000 (64-bit, non-prefetchable) [size=4K]
Memory at f8000000 (64-bit, non-prefetchable) [size=4M]
Expansion ROM at f8400000 [disabled] [size=256K]
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI-X: Enable+ Count=32 Masked-
Capabilities: [a0] MSI: Enable- Count=1/32 Maskable- 64bit+
Capabilities: [c0] Vital Product Data
Capabilities: [150] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [180] #19
Kernel driver in use: atlantic
Kernel modules: atlantic
45:00.0 Network controller: Intel Corporation Device 2723 (rev 1a)
Subsystem: Intel Corporation Device 0084
Memory at f8b00000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
Capabilities: [14c] Latency Tolerance Reporting
Capabilities: [154] L1 PM Substates
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
46:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
Subsystem: Micro-Star International Co., Ltd. [MSI] I211 Gigabit Network Connection
Flags: bus master, fast devsel, latency 0, IRQ 52
Memory at f8a00000 (32-bit, non-prefetchable) [size=128K]
I/O ports at 2000 [disabled] [size=32]
Memory at f8a20000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=5 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number 00-d8-61-ff-ff-d7-1d-bc
Capabilities: [1a0] Transaction Processing Hints
Kernel driver in use: igb
Kernel modules: igb
47:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Flags: fast devsel
47:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
Subsystem: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
Flags: bus master, fast devsel, latency 0, IRQ 94
Memory at f8700000 (64-bit, non-prefetchable) [size=1M]
47:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
Memory at f8600000 (64-bit, non-prefetchable) [size=1M]
48:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51) (prog-if 01 [AHCI 1.0])
Subsystem: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
Flags: bus master, fast devsel, latency 0, IRQ 145
Memory at f8900000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [a0] MSI: Enable+ Count=1/16 Maskable- 64bit+
Capabilities: [d0] SATA HBA v1.0
Kernel driver in use: ahci
Kernel modules: ahci
49:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 146
Memory at f8800000 (32-bit, non-prefetchable) [size=2K]
4a:00.0 Non-Volatile memory controller: Phison Electronics Corporation Device 5016 (rev 01) (prog-if 02 [NVM Express])
Subsystem: Phison Electronics Corporation Device 5016
Flags: bus master, fast devsel, latency 0, IRQ 60, NUMA node 0
Memory at f9100000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [80] Express Endpoint, MSI 00
Capabilities: [d0] MSI-X: Enable+ Count=9 Masked-
Capabilities: [e0] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [f8] Power Management version 3
Capabilities: [100] Latency Tolerance Reporting
Capabilities: [110] L1 PM Substates
Capabilities: [128] Alternative Routing-ID Interpretation (ARI)
Capabilities: [1e0] #25
Capabilities: [200] Advanced Error Reporting
Capabilities: [300] #19
Capabilities: [340] #26
Capabilities: [378] #27
Kernel driver in use: nvme
4b:00.0 Non-Volatile memory controller: Phison Electronics Corporation Device 5016 (rev 01) (prog-if 02 [NVM Express])
Flags: bus master, fast devsel, latency 0, IRQ 62, NUMA node 0
Memory at f9000000 (64-bit, non-prefetchable) [size=16K]
4c:00.0 Non-Volatile memory controller: Phison Electronics Corporation Device 5016 (rev 01) (prog-if 02 [NVM Express])
Flags: bus master, fast devsel, latency 0, IRQ 63, NUMA node 0
Memory at f8f00000 (64-bit, non-prefetchable) [size=16K]
4d:00.0 Non-Volatile memory controller: Phison Electronics Corporation Device 5016 (rev 01) (prog-if 02 [NVM Express])
Flags: bus master, fast devsel, latency 0, IRQ 66, NUMA node 0
Memory at f8e00000 (64-bit, non-prefetchable) [size=16K]
4e:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Flags: fast devsel
4f:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Flags: fast devsel
60:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Flags: fast devsel
60:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Flags: fast devsel, IRQ 27
60:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
60:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
60:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
60:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
60:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
60:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
60:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 57
Bus: primary=60, secondary=61, subordinate=61, sec-latency=0
60:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
60:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 59
Bus: primary=60, secondary=62, subordinate=62, sec-latency=0
61:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Flags: fast devsel
62:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Flags: fast devsel
