So I've been in the console scene for the past 4 years and now, this Christmas, I have decided to make the switch.
I was wondering if I could get some recommendations before I get the new computer. I don't care which category they are, anything to start me out with some cool and fun games would be nice.
My specs are going to be:
FX-8350
GTX 760
16 GB Ram
1TB Storage
Windows 8.1
I was also wondering if my pc would run battlefield 4 at a good 45 fps, and even if it could, is it worth the $50, or should I just buy battlefield 3 for $10? Haven't played BF4 yet, but I have BF3 for Xbox.
Sorry if this all has been posted before, I can't find the search button -_- haha
In my opinion you would be better off saving money and going with 8GB of RAM unless your planning on having lots of resource-hungry applications running at the same time. I have 8GB of 1600Mhz and have not managed to use it all. Everything else looks good. You didn't list a motherboard. Battlefield 4 will run just fine, I have a GTX 660 and a FX 6300 and I get anywhere from 40-120 FPS. I have to turn off anti-aliasing or else it's very laggy. Other than that it's buttery smooth at 1080p. You PC will be as good as or better than the newest generation of consoles. Civilization V is good, Command and conquer, Metro Last Light, Splinter Cell: blacklist, Starcraft, Skyrim, Anno 2070, Crysis 2 and 3
Alright, then things are looking up for me. Also, I have already ordered the computer, so I cant change the 16 gb of ram. I do graphics design and 3d work though, as well as render videos, so the extra ram couldn't hurt. It also helps me future proof a bit. And I will check out those games!
Your setup is pretty similar to my pc. I have a gtx 760 core i5 4670k both oc'd and I can play BF4 at ultra at a smooth 60 fps. You should be able to run pretty much any game better then the consoles will ever be able to
Sounding really good to me! Also if you don't mind me asking, what programs did you use to over clock them, and what did you clock them to? I have never oc'ed an GPU before, but I have oc'ed a CPU, so I have a good understanding of what I am doing. And would you have any game recommendations for me? Thanks!
overclocking your gpu is really easy, just download msi afterburner and some graphics benchmarking tool like valley benchmark just move slightly adjust the sliders till you get something stable. For you CPU is could be really easy depending on your MOBO. Not sure how it is with some AMD motherboards but if you have one from ASUS with UEFI there should be an option to just use AI Suite with is an idiot proof way of over clocking your cpu by just clicking a button. Otherwise you'll have to go into the bios and adjust your multiplier number till you get something stable.
remember you will need adequate ventilation to keep everything running cool. There are plenty of videos online to show you how. I recommend Jayz two cents, he has a video on overclocking amd cpus
Alright man, will check him out. Anything else in general I need to know about PC gaming? Any do's or don't? I am another one of the fresh batch of PC gamers. I will still need to check out mods and things like that for games!
Try this. Its where I go to look for games first, since it helps find the best deals. There's been many a time where I've gotten a game for $10 my console friends have paid $40 for.
There's a lot of mods out there, sites like moddb.com, planetphillip.com (for Half-life), gamebanana.com, (most mods sites are specialized forums). There's no don't other than to not buy crappy games and support a greedy talentless company.
I recommend open mindedness, look into indie exclusives, older established titles like doom, quake, half-life, warcraft, starcraft, civilization, avp, wolfenstein have a lot of custom content and also producer expansion and sequels (probably not as good as the originals but the pre-dlc era was golden in comparison to today).
Also check out all sorts of genres, from puzzle, sims, strategy to shooters and twitch-reflex games. Chances are you'll find a lot of genre-bending titles you'll like.
