At this point I have been messing with this for almost two days and I am not sure what I am doing wrong, I am following a guide as I am new to VFIO pass through, and so far I have added iommu=pt amd_iommu=on rd.driver.pre=vfio-pci video=vesafb:off,efifb:off
to /etc/default/grub, blacklisted nvidia and noveau drivers, enabled these modules
echo “vfio” >> /etc/modules
echo “vfio_iommu_type1” >> /etc/modules
echo “vfio_pci” >> /etc/modules
echo “vfio_virqfd” >> /etc/modules
and added my device to /etc/modprobe.d/vfio.conf by running
echo “options vfio-pci ids=10de:128b,10de:0e0f disable_vga=1” > /etc/modprobe.d/vfio.conf
I then ran sudo update-grub2 and sudo update-initramfs -k all -u
After all of that, I rebooted and attempted to start my vm, however I get the error:
(qemu) qemu-system-x86_64: -device vfio-pci,host=01:00.0,bus=port.1,multifunction=on: vfio 0000:01:00.0: failed to open /dev/vfio/13: No such file or directory
and when I run lspci -nnk I see that the vfio-pci driver has not grabbed the gpu.
My computer is a Ryzen 5 2600, and 2060 I’m using as my main gpu for video display and a GT 710 that I’m trying to passthrough, and I’m running POP_OS 20.04, and I am using grub2 instead of systemd-boot
