Yeah, ideally you have cameras dedicated to the external doors so those can be set to motion detection and the rest can record constantly or on a schedule or whatever you like.
You can get shielded variety of any cat cable. Cat6A is what you want for 10GbE or 10GbE future-proofness.
This could have changed but cat7/8 has historically been marketing gimmick. Not sure if the actual Cat7 standard ever got finalized. In any case, 10GbE is the fastest RJ45 option that is widely used and remotely affordable, so no need to go beyond Cat6A.
Shielded cable is usually for outdoor or high interference environments and requires a grounded patch panel. Itās kind of a headache. Iād avoid it unless you need it.
Car6A is rated for 10GbE up to 100m so I wouldnāt worry about that. If the cameras are outside though, shielding might be a good idea. Iāve honestly never run anything outdoors so I donāt know what the best practices are with utp vs stp in that case.
Probably overkill. Usually the stp grounds to the patch panel which grounds to the rack which grounds to whatever is readily available. If you have full sized racks full of $5/6 figures of equipment, then yeah make sure thereās a dedicated ground, but otherwise spend your money elsewhere.
I use one of these to ground the coax that comes into my apartment through a normal outlet.
Unifi access points are good.
Unifi switches are good.
Unifi routers are simple to setup, but the configuration options in the control panel interface are quite limited. And anything you do via the command line is at risk of getting wiped out the next time Ubiquiti issues a software update. So I would not recommend the Dream Machine, or any other Unifi routers
I would suggest Unifi switches and access points, and pfSense as your router. pfSense has a multitude of settings, and on top of that thereās a built in capability to download and automatically install a variety of add on packages. You definitely wonāt outgrow it.
This is a fairly common combination so you can find YouTube videos for things like setting up VLANS.
You can install the pfSense software on your own hardware. Or you can buy a router from Netgate Systems with pfSense already installed. Netgate are the maintainers of pfSense.
pfSense runs on pretty much any Intel or AMD hardware made in the last decade. So you can test it out if youāve got a pc available and can lay your hands on an extra Ethernet NIC.
It is a bit picky about having good Ethernet ports, which means Intel, and not Realtek. You can check the compatibility list.
As others have mentioned, there is also OPNsense, which is a fork of pfSense. Iād suggest going with pfSense to start because I think youāll find a lot more tutorials online for it.
One further thing to mention if buying Unifi access points.
A lot of people buy the Unifi AC Pro model thinking that will give them better wifi performance. The benefit of that model is that it can do a better job of handling a lot of users at one time. Like in a very crowed office, a shopping mall, or a sports arena.
For a lot of people the Unifi AC/LR can be a better choice. LR stands for long range. Itās antennas are designed to work at a longer distance for both sending and receiving.
The AC Lite, AC/LR, and the AC Pro are all rated for 250+ users.
Iām pretty sure Iām going with pfSense router after doing a little more reading.
I have some older boxes that might be good candidates but they have issues making a new NetGate box look like the least painful!
WAP; I think it would be beneficial to go with a AX. It is kinda like the PCIe Gen 3 vs 4 PC build. I went Gen 4 because I felt it was a safe bet the industry would start supporting Gen 4
The only reason I am looking to spend money on WAP is for our phones. We must use Wifi calling or else phone conversations donāt last very long due to dropped calls.
If learning, ⦠Maybe get a NanoPi R4S with Debian as a router⦠or even R2S ⦠(they have hardware crypto support unlike rpi making them good candidates for VPN). As long as you donāt have a faster than 1Gbps internet connection theyāll be good. With 4GB ram on it, it may even be able to run some containerized services⦠e.g. a sync thing server, a something cloud, or just a plain old target for rclone backups, or it might run a unifi controller for your VLAN switch and WiFi
I donāt know for sure, but maybe an amlogic s922x based odroid n2+ with a usb dongle for a second nic would be a good choice too, the cpu is slightly more modern than rk3399 found in R4S.
