Hello every one I am trying to build a cheap HTPC for in home streaming from my gaming rig in the office. I have this build so far: http://pcpartpicker.com/p/DdXgCJ.
You will note that there is no psu as I have a Corsair 650w non-modular on hand for the build. I am however concerned that the bulky cables may prevent from building in this case, however I am not sure.
I also have a optical drive to install into it if I need to use one for any reason.
So this brings me to my most important questions:
1. Will I be able to use a copy of windows 7 that I use on the other 2 pc's I have running or will I need to buy a third?
2. Will I be able to stream to this rig using my main rig with a gtx 680 without using a graphics card? I plan on getting a 970 soon and will put my 680 in my girlfriends rig and take her 560ti for use in this build if need be.
3. Is there any cheaper way to do this without getting a hdd or smaller ssd, but mainly will I have H.264 on this rig without using a graphics card, if not what is the cheapest way to get that.
I have controllers, mice, keyboards, etc for the rest of the build but am just unsure if there is a better way to do this.
Thanks in advance for the advice and I will let you know how the build goes and of course the end results.
PS: Here are my other two systems for reference:
Mine- Corsair Obsidian 450D
Core i5 3870k
Evga P67 sli Micro
Evga gtx 680 4gb ftw
Evga Supernova 850G2 PSU
16gb Corsair XMS 1333Mhz RAM
2TB HDD and 500GB Samsung 840 EVO
Hers- Corsair Graphite 600T
Core i5 2500k
Evga gtx 560ti
AsRock Z68 Extreme 7 Gen 3
Seasonic 760w PSU
16gb Corsair Ram
2TB HDD, 250GB 840 SSD, 120GB Corsair SSD
