In Game Benchmarking and Reporting
Greetings,
I think it would be helpful if more Game Developers included a in game bench marking tool.  Also another function that would be useful would be 4 reporting tools that you could enable on screen during game play such as the following:
CPU Usage
System Ram Usage
GPU Usage
GPU Ram Usage
If you really wanted to get into the nitty gritty then also include HD usage specifically for that game.
The Benchmark tool would be good especially for people with older cards that wanted to know what other people with newer cards are getting (Results), and perhaps help them in choosing a newer card.
Just my Idea, what do you think?
there's this program  called fraps that does that for any game usually.
you can use gpu-z on a second monitor to monitor GPU speeds temps etc and framerates can be seen by Fraps but also dxtory and other game capture software as well as others such as razer game booster but I do think that there should be a easy program that overlays all the necessary statistics.
Hey Thanks! I'm gonna use Razor Game Booster!
