Im trying to build a gaming pc for around $800
ive seen on youtube people building computers for $800 but then when i actually add up all the parts its like in the $1.000’s can anyone help me
What do you have on your old rig that is still good?
Microcenter near by?
What monitor? Plan to upgrade Monitor?
You can build a basic rig then add upgrades as time passes.
Do you want to go less then 800?
What are your fav games?
On one build I spotted an Antec case with PSU on Clearance half off cause it had a scratch, that is just an example of some of the things to look for when trying to save a few bucks. Also people on youtube usually use the top end stuff they get for free, Many times you can find cpu/MB combos that can save a few bucks.
Also if your not OC’ing a stock cooler is fine or a 25 buck aftermarket one
Prices vary by time and vendor.
What specs are you looking for? What games do you play? Do you have any parts you can re-use?
Wendell’s team red budget build (~$800ish)
Bitwit, LTT & Pauls Hardware have all built builds for $1000 or less in the past couple weeks.
Bitwit just did an XBOX mini-ATX replacement build and parts list here: (pcpartpicker.com/list/cv2fDx) if you drop down from 2070 SUPER to 2060 KO you’d be right in your budget, but I’d never want to build in those tiny cases, personally.
Basically you’d be shaving about $200 off a Ryzen build by subbing the 1600AF or shave $150 off dropping down from the 2070 SUPER to either 5700 or 2060KO, and still have upgrade options in the future for you on AM4 when you can drop some more money on a nicer processor.
