Building a PC...
Used for: Gaming (mostly)
Will pay: $800-$1000 (USD)
Would like: The ability to upgrade, speed (all of it).
I've looked on about 4-7 forums (tom's hardware, this sight [duh], overclocking.net, Linus's site) and have read reviews on amazon, newegg, and the like before I choose my parts.
I used PC parts picker for compatibility checks.
Build link here: http://pcpartpicker.com/p/2s3au
Yes, I know I don't have a case or cooler, more on that below.
*NOTE* The prices are up for debate; if you know where to get a cheaper equivalent part, I'd like to know.
I don't care about the case so long as it has all the right slots and decent enough airflow.
Yo.
Stupid question ---> Do I need a cooler specifically for the CPU? I'm reasonably sure I do but am unsure of what coolers are both of high quality and reasonable price.
I don't know what specific components necessarily (Mobo, cooling, PSU, RAM, SSD) should cost; am I getting what I want for a decent price? Have I sucked out horribly and am paying for things I don't need? Any advice would help.
I lied.
No fanboi advice.
Thanks in advance.
looks ok, I've heard some pretty bad things about cooler master power supplies, I personally swear by corsair cx on the cheap side
no, you don't need a cpu cooler, by which I mean it comes with one, not going to say it can't get loud but it'll get the job done
Thanks a bunch for your input; it's fine by me if it's a bit noisy. Exactly what issues have you heard about with cooler master? I'll take your advice but would like to know for future reference.
I wouldn't call you retarded. I think you have a solid build! Nothing really "wrong" with it.
http://pcpartpicker.com/p/2stKE
All I did was change some things out based on preference.
I would advise changing the stock cooler, even if you pick up something cheap for < $30. The stock cooler isn't known for longevity, thermal performance, or acoustic performance. However, there is no immediate need to replace the stock cooler.
Appreciate the help. I noticed the ram you picked is 1600 instead of 1866. Is there not a significant enough difference to justify buying the faster ram?
In short, no.
Some say that 1866 feels a bit snappier. I just moved from 1866 to 1600, and I can't tell the difference. Faster RAM doesn't make your in-game performance noticeably better. The performance difference between 1333 and 2400 is 1-2%.
For video editing and that kind of productivity, I would aim to get RAM with lower latency before I considered a faster clock.
Other than the whole having to take apart the entire computer to put a new one on...
Just bite the bullet and get a CPU cooler, they aren't much... Intel's will do the job for the most part but AMD's stock coolers are paperweights...
I upgraded from 8GB DDR3-1333 to 16GB DDR3-1866 when I did my recent remodel, and all I noticed was video processing goes faster...
I agree.
However, the Fractal Core 3000 has a hole cut out of the motherboard tray. So he could change the heatsink without taking the computer apart. Because there is access to the back of the motherboard, which the Core 1000 doesn't have - I think.
In that case I'll go with the 1600 you picked. (Buying the 4gb sticks separately because it saves me $2.5)
Nothing wrong with your build except the Cooler Master PSU I just seem to read more negatives than positives. You didn't say how good gaming performance you wanted. Since you said you wanted to upgrade later you could save some cash and go with this. yes the performance is less than what you posted but 6300 w/ 270x is going to be able to be able to play every game at or close to Max settings
http://pcpartpicker.com/p/2svsH
The CPU cooler just going to help keep temps slightly and need to change the ram to something low profile so the cooler would fit. finally changed the case so that you will have no limitations in what kind of upgrades you may want to do in the future.
I had the same thoughts about noise when I built my first gaming rig. This will change quickly, trust me. I didn't have much help when I was first getting into it and the only guy I knew just said to make sure I used something other than the one it came with. Well I picked up some cheap ass rocketfish cpu cooler from best buy *shudder*. Once I turned on the pc it sounded like a chinook helicopter was firing up in my room. It's better to spend a few extra bucks on a half way decent one when you can. It's absolutely worth it.
