I'm not Sure which CPU Cooler
Hy Guys,
I'm getting a headache at the moment because i dont know if my motherboard, CPU-Cooler  and Ram will fit  together (space).
 At the Moment  i plan my new Computer System
I want to use:
Motherboard: Gigabyte GA-990FXA-UD3
http://www.gigabyte.us/search/search.aspx?kw=GA-990FXA-UD3#pr-1
RAM: G.Skill Sniper DDR3-1866 CL9  (42mm height)
http://www.gskill.com/products.php?index=385
CPU Cooler: Thermalight Macho Rev.A(BW)
http://www.thermalright.com/html/products/cpu_cooler/macho_reva_bw.html
Please help me,  its my first own Build.  Will this  Parts will fit together (space) ?
(just for completion the other hardware on the board^^)
--> Processor: AMD FX 8350
-->GPU : Sapphire Radeon HD 7870  OC )
Thx for any Help :)
these parts should work together.
 it will be very close but it will fit less than a cm between the two (ram and cooler)
thanks for  the answers Guys :)
well close you say?  hmm  maybe  which cpu cooler, would be a better  choice (  good cooling too,  and   not so close to the Ram)?
