Title explains it all and i would like for a gaming pc under $650 that could run all games on ultra or High and yes i would like a GPU
If you're willing to go up to $700, this build is pretty sweet. If not, just go with this build. You're not going to be running every game on ultra but most games should play fine
this is the best i could do you should be able to play BF3 an ultra between 40-60 fps ($663 before shiping, $677 with shiping, and $647 after shiping and rebates.)
if you can find a cheaper power supply take that exstra money and upgrade your ram to something with better timings. and you'll have to find a dvd rom or install your OS via usb
and i tried to do an intel build first but i couldn't get it under buget with out using crap parts.
http://www.tomshardware.com/reviews/radeon-hd-7870-review-benchmark,3148-6.html
MB (crossfire /sli ready) http://www.newegg.com/Product/Product.aspx?Item=N82E16813130637
gpu http://www.newegg.com/Product/Product.aspx?Item=N82E16814150605
cpu http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
psuhttp://www.newegg.com/Product/Product.aspx?Item=N82E16817153125
Ram http://www.newegg.com/Product/Product.aspx?Item=N82E16820313266
HD http://www.newegg.com/Product/Product.aspx?Item=N82E16822145304
cass http://www.newegg.com/Product/Product.aspx?Item=N82E16811235026
A HD 7770 will not play games on ultra nor high @ 1080p
WTF? I'm sure I already posted a response in this thread... The fuck happened to it?
W/E I'll repost the build
http://pcpartpicker.com/p/lggd
