So, after a few beers, and in light of Jupiter Broadcasting's LAS Arch Challenge, I've decided I'm going to nuke Windows on my Acer AO722 netbook and jump to Arch (pure Arch, not a derivative, such as ArchBang or Manjaro). I'm keeping my Mint install in case things go south. I guess the thing that finally pushed me was Matt's recommendation. He said something along the lines of if you've ever broken Xorg and had to fix it, then Arch just may be for you. So, I'm making the jump. Plus I wanted something I bit more efficient to run on my netbook. Currently running Linux Mint 14 x64 w/ GNOME Classic + Gnome Do.
I'll post updates to help anyone else on Teksyndicate who is considering the jump to Arch. I've been strictly an Ubuntu/Mint user since about 2008. I've played around with various DE's, and have gotten my feet with CrunchBang Linux. If I had to rate my Linux skills, somewhere between intermediate to advanced.
Well... let's fire it up. I'm going to try a netboot, which I have never done before. Here goes nothing...
UPDATE 1 - After an hour of trial and error, I finally successfully booted into the Netboot environment and is now downloading. In all fairness, this is my first time ever trying a netboot, and only my second or third time, first time in over 2 years, that I've ever had to edit GRUB, much less make a custom menu entry. It was pretty straight forward, but I made a few bonehead moves, such as not correctly setting the root partition, using mismatching brackets, forgetting to use sudo when downloading to a system dir and wondering why my download wasn't there, etc. As an update to my update, I've now booted up into Arch. Now, time to figure out how to initialize the install process from here...
UPDATE 2 - I successfully(?) installed Arch from a netboot environment. I got both wired and wireless internet working, and I believe I might have gotten Xorg working with AMD drivers, but I made the mistake of skipping GRUB installation, since I previously had Linux Mint installed, and I didn't want to nuke Mint's GRUB config on accident. I needed to add a nomodeset parameter, but I didn't want that to affect Mint in any way, and, well... long story short, I'm struggling with GRUB and keeping settings from Mint and Arch separate. I'm also having trouble getting GRUB to even recognize Arch half the time. Every time I run update-grub, it's anyones guess if Arch is going to show up upon reboot. I think I'm going to bed. I felt pretty good, and it was a heck of a learning experience. I had a lot of fun. I think I'm going to try it tomorrow, but I'm going to try the graphical installer, and this time I'll be sure to re-install GRUB, and format my partition properly. If I screw that up, I figure I can use my Mint LiveUSB and repair/reinstall GRUB to at least boot Mint again. Mint survived my adventure with Arch. :)
