So I'm looking to build a new computer for college but I'm a little stuck.
Price: $1000 - $2000
CPU: i7 - 4770K or i5 - 4670K
Cooler: Water cooled closed loop like the H100i or Kraken X60, this can change based on the case if i cant do water and need air
GPU: GTX 680, 770, 780, or 780ti
Motherboard: (i have no idea about what i need other then on board needs at least wireless n)
Case: i really like the NZXT 530 but i would like to know about more portable options. it needs to have 3-4 3.5" bays
RAM: 16GB, I'm not sure about what latency is good or not.
PSU: 750W+
Storage: an SSD would be nice but not if its smaller than about 250GB, i know there are 240GB some where, and i have extra 1TB HDD's for the PC.
i think that's it, comment if i missed anything and ill add it and comment any products that would fit well in my build.
Thanks!
Well, here's a nice small form factor build. Since you have such a large budget range, if you find something you don't like, you can switch it out.
Also I don't know how much storage you want. The Node 304 can hold up to 6 2.5/3.5 drives. I didn't bother with a 750w PSU because you're really not going to pull 750W out of an Intel ITX system.
http://pcpartpicker.com/p/2BvSk
750 watts is overkill but leaves room for another card if you go not mATX or mITX
http://pcpartpicker.com/p/2BvX2 <---Mid tower
http://pcpartpicker.com/p/2Bw7W <---mATX mini tower
http://pcpartpicker.com/p/2BweX <---mITX
ARedneckSquirel's builds above are solid. As some other options though, you could downgrade to the i5-4670k - Personally I think you'd notice the reduction in price more so than the drop in performance. If you already have peripherals then you could also squeeze in a GTX 780 Ti should you feel like it and remain under budget. I'd also recommend the Samsung 840 EVO 250GB SSD over most else, its a little more expensive though.
As for the PSU, I'd run a 750W minimum for this system. Most PSUs have maximum efficiency at about ~50% load and the price premium is minimum over lower rated PSUs. Another plus is it won't sound like a hairdryer when your system is under load.
All the best with your build!
this is what i put together: http://pcpartpicker.com/user/nizzy2k11/saved/3rMP
- i decided that portability would not be so concerning to me so i went with the Phantom 530
- i have a HDD to use for mass storage
- i really want the 780ti
- i know the X60 fits in the case so i went with that but for the $25 i don't think i would like to risk the H100i
that's it, tell me what you think i could change or a part that is better for the price.
Phantom 530 is big :D. If you're not going to be moving it, it'll be just fine.
If the X60 fits as a 280mm radiator, the 240mm h100i should fit just fine.
There won't be much of an improvement in gaming between an i5-4670k and an i7-4770k. Just giving you a heads up on this.
Everything else looks fine.
i may chose the i5 but i don't know what i will do. if i want to use it for streaming i think the i7 will preform much better.
