Started building a new computer. Let me know what you think. Here's a laydown of the specs. I have never built a computer before and I'm buying it peice by peice cause I want it to be a high end PC. Not to high though like dual CPU's and shit. But high end as in 16Gigs of Ramm and a decent GPU high end.
NOTE: Everything is Red or Black or Both.
CASE: Cooler Master HAF X
POWER SUPPLY:Corsair GS 700 Watts
MOTHERBOARD: Asus Maximus V Formula Thunder FX
CPU:i7 3.4 GHZ w/ 10MB Cache Z77 Chipset
GPU:Asus HD 7850 Radeon 2GB
RAM:Corsair Vengence (red) 4x4 16GB DDR3 2133MHz
HDD: Western Digital 2 TB Black
SDD (for os) OCZ Tech. 128 GB 2.5 Inch
CPU COOLING: Corsair Hydro Series H100 Liquid Cooling
bigger SSD and maybe a lot higher end gpu like a 680 (or a 690 :O) then u may be getting into beast territory. also i wouldnt build it piece by piece, save up money and buy all the pieces at once
I recently asked for help on here and was going to get a GeForce 670 but was convinced to go with a Saphhire Radeon 7970 instead because of benchmarks and temps. Keep in mind that the Radeon will need a bit more power so make sure your PSU is up to the task.
you could get a evga gtx 670ftw their about $20 (i think) more than a standard 670 and they out perform the gtx 680 in quite a few games, also they have the gtx 680 pcb and stock cooler
