My parents are going to vegas in a few weeks and i was just wondering what everyones kind of dream setup would be
Here's an idea of what mine COULD look like
http://uk.pcpartpicker.com/p/pYgst6
Leave any thoughts in the comments below
EDIT: Here is another build
http://uk.pcpartpicker.com/p/FPD8bv
Choose which one is better and give suggestions on what to change
Nevermind all the bells and whistles, the performance, and whatnot. I just want to make my system significantly smaller, without sacrificing some of the additions I made. The motherboard is the only exception, since, I would need to change it to an mATX board. Get it into a cube case of some sort.
There is no CPU cooler, it'd catch fire or die.
if you looked properly there is a full custom water loop including a cpu block
I did, it wasn't there a short while ago; probably an issue with pcpartpicker.
Theres no way I would be able to put up with 4 way SLI it would drive me crazy...
http://pcpartpicker.com/p/LhK8bv
If I had the money to blow...
