If i can get a swap, what graphics card should i g
MY 4870, XFX have done a bad job of these cards so I'm going to ask where I bought from for a swap for something of the equivalent price because atm they are doing a direct replacement but it's not the card, xfx have got everything wrong since they just started making ATI. So I was thinking a nVidia, but any suggestions are good. I payed about £180 dunno what that is in $ so any good cards you know for that price?
A gtx 260 core 216 I think is the only card that is about £180 but I am not sure.
Ronnieb555 wrote 1 minute ago »
do you know if its any good?
I like the sound of this one :D http://www.ebuyer.com/product/150341
google some reviews, lulz
GTX 260 has about the same performance as the 4870 so it would be your best bet for a replacement nvidia card. You could also consider a GTS 250, not as fast but alot cheaper, if XFX dont really want to swap a used card for a new card of equal value this could be worth a try.
I think the only card i'd buy right now if I needed one would be a 9800GTX+ or a 4830
Then again i'm a cheap ass like that.
no buy an XFX ATI card they are awesome
stick with a new xfx 4870.
