So, I’ve been looking at one of my previous posts about Java on/included with earlier versions of Mac OS, Mac OS X, but for earlier versions of Mac OS, Mac OS 9, and below, and I am wondering how you would/one could, etc… identify which/what Java version you have/would be included.
When I tested/tried to extract Java information from my copy of Mac OS 9, it did NOT have/include a Terminal, so I couldn’t do the usual:
java -version
I was wondering if anyone knows if there’s a way to identify which/what Java version you would have/be included for these older operating systems.
Easiest way is probably to locate your Mac OS Runtime for Java (MRJ) folder as Apple developed their own tools for Java support back then. Once the MRJ folder is open, Open the Apple Applet Runner folder, select the Apple Applet Runner program icon, open the File menu, and open Get Information.
