Ideas to turn on pc without case
So for my next build i'm planning not to care about the case because why should i. But i don't want to turn on my pc
with a screw driver every time. (If you don't know to turn on PC you have to connect 2 jumpers with screwdriver)
What little gadget or invention or thingamajig could you think of so all the test-benchers everywhere could turn on their PC without hassle. Or is there already a thing on the market that solves this problem
THANKS :D
canablize a switch off some win95 POS
or go to a radioshack that actually sells switches
yeah, just buy a button switch.
http://www.amazon.com/Mainboard-Power-Button-Switch-Connector/dp/B00H8Q366O
Thanks!
Thanks, But i know what to do now, ill just tare the whole io front panel from this crappy case i have.!
good idea. the force be with you.
You can put something metal over the power headers on the motherboard to short the pins and turn it on.
he was using a screw driver.
I mean a kind of switch.
I tore that front IO like it was the throat of my opponent in This is sparta!!
you mean 300
I meant what i meant...Good day sir.  -_o        ;
