Ideal computer system?
Hey guys,
I need some help. Can anyone suggest me a computer that I can buy in Canada? This computer needs to be able to play some of the newer games on MEDIUM quality, at around 50-60 frames. I'd like the price to be around $600-$900. That is my comfortable price range. I'd like the computer to be very customisable so that I can keep this system for a while.
I'm not that knowledgable with this stuff, as you can probably tell, so I would also request a short description as to why I would buy that part, etc.
I know that I may be asking for a lot, but if anyone can do this, I would greatly appreciate it.
P.S - You don't need to put that description part, but I would really like it if you could :D
Thanks
So, do you want parts, or a complete computer?
Complete , please. With the parts, of course.
Ex:
CPU: xxx - (Description here, why should I get this? What is so good about that type?)
GPU: xxx
etc
http://pc.ncix.com/pcbuilder/index.php?action=config&id=3928620&platformid=1001
http://pcpartpicker.com/p/soJi
Thanks so much guys!
the build that I poseted should be amazing and 40 FPS + on every game max
drop the CPU to a 965 black edition or 4300 if need be.
and if you need to save even more money go with a 7850 but you will not be able to max things out comfortably
Do I need to order every part individually? Or is there some way to order it all at once? VERY new to this. Never ordered antying in my life before :S
Thanks though
You can do it individually or all at once. It's like any other shopping cart online. Newegg.ca or NCIX.com is good reputable online E-tailers.
Look at ncix if your from Canada they have some good custom builds to model from or buy.
I've made a new system. I'd like to know if anything conflicts with anything else. I don't think it's enough power for what I want, for example.
Here's the link: http://pc.ncix.com/pcbuilder/index.php?action=config&id=3934460&platformid=1000
Thanks
Your psu is more than big enough.
I would advise a different CPU cooler (CM Evo 212) as the stock AMD coolers, although good, are terribly loud when they spin up.
Again PSU is plenty powerful enough.
Nothing else conflicts? Also, which cooler do you suggest? What PSU would you recommend for this build with a little bit of overclocking, say 3.8 GHz? If I can even go that far...
Thanks
Thanks guys for all your help with this. In the end, I just said screw it and I killed it :P
Here is my system: http://pc.ncix.com/pcbuilder/?action=config&id=3934460
It's not the best thing I could come up with, but it's sort of within my price range, and it can do what I need.
Thanks again
