IceLake Vs TR Pro
Hey all so i recently just purchased a TR 3945WX and Gigabyte Board for around £1100 and ive recently been seeing the Icelake Xeons + Motherboards for Roughly the same price if not cheaper for the Same 12c/24T + motherboard and honestly not sure if im having buyers remourse or something but I keep thinking about buying the Xeon instead but it seems i cant find any benchmarks or results vs the 2 chips at all, Does anyone have any experience with the Xeon icelake silver chips (Xeon 4310) and or the (Threadripper 3945WX) since Id like to hopefully make the best decission on what Platform i should buy into since ill be using this machine/platform for the next few years for my Uni/Intership + Home projects and other simulations so just really want the best bang for the buck and since this is my first time buying into a HEDT/Server platform i dont want to make the mistake of buying into a platform that may die in a few years due to still being on DDR4 and other things.
And since im still able to cancel the TR + Board purchase id be able to get the Xeon if it would perform any better vs the TR.
DDR4 will still be viable for a long time. Esp. regarding price / compatibility / Gen1 quirks of DDR5. Either platform is working with DDR4 anyways [+ you have a large memory ceiling in your favour]. You got a bigg cache and Zen3; don’t worry about your purchase … IF necessary, can always go for bigger core count
Thanks! that was my thoughts really that DDR4 will still be around and maybe get cheaper aswell what will be nice to finally upgrade to 256gb or higher from 128gb and well yeah upgrading cores will be my first actual upgrade just couldnt justify the 32 or 64 core at the moment so got the OEM 12 core for super cheap. I guess since its still pretty expensive and im just worrying for no reason, thanks for helping me clear my head about it aha
