I9 14900k μCode flaw
Hello
i bought my i9-14900k back in 01-12-2023. i was experiencing a thermal throttle but there is no obvious signs of flaw in my cpu used mainly for compositing and vfx applications. There was a gpu drivers install test to determine if your cpu was affected by the μcode issue which was passed.
is there any other way official to test the cpu?
Should we keep the cpu or RMA?.
My build is
MSI PRO B760-P WIFI DDR4
Intel(R) Core™ i9-14900K 3.20 GHz
MSI GeForce RTX 3060 12GB GDDR6 Ventus 2X OC
Corsair Vengeance Lpx 128GB DDR4 RAM
Ive done all the Bios updates.
Thanks
Hello @gnmeles and welcome to this forum!
If you think, that your CPU isn’t working correctly, I suggest, that you contact the Intel support team.
I’ve got an open RMA case with them too.
