i7 processors - worth it?
Are these really going to be a lot better than the quads that are out now? I'm going to be building a new PC next March so the i7's will be out then. Should I get one of these or just a quad? Unless the i7's are going to be necessary to play newer games I don't see what the point in getting one is.
i would, im sure they will be better, probably not crazy better but at least you will be on the new socket. u will get more life out of you motherboard that way. idk, i guess it all depends on the price and how they end up performing.
Lol, if it wasn't for DDR3, it probably wouldnt be too much more expensive!
nope
alot of games still dont support these kinds of cpus also the quad cpus.
i would go with a quad for futureproof.
Duel cores are still req but quad core will futureproof.
quadcores were made for modeling and movie makers. but now games are allowing all 4 cores to be used but not most.
duel cores will be the new singal cores cpus.
quad cores will be the new duel cores.
these new cpus will be the new quad cores.
so a quad core cpu will last for 1-2 more years tops.
Lol, you're right about i7 being the new quad cores, they're quad cores(most of them will be anyways), and they're new!
