So my tech friends, I have a quick question for you experienced water coolers out there.
I am running (as the title states) i7 4790k and gtx 780 Ti all watercooled. I will be overclocking it all hard, probably even
overvolt the gpu. So I guess my question is this:
Is 480mm radiator able to cool this system with everything oc'd?
The rad will probably be EK Coolstream PE because it is high fin density, but quiet(dual fin design), I know JayTwoCents did an overview (Very very good airflow for 38fpi rad).
Here is the link, https://www.youtube.com/watch?v=ZkdUx1oUR8A
Anyway, I just wanted to know if I need and additional 240 or 280 or some such rad.I will be running Noiseblocker E-loops PWM if it is helpfull (800 - 2400 rpm)
Or maybe Aerocool Dead Silence, cant decide yet. E loops i can ramp up for hard oc's or benchmarks but DS fans state that they have higher SP (on the website, but i am not sure if I should thrust it )
Thx.
P.S. If you guys have a better rad of fan to recommend please do, just that it isnt Alphacool since I cant find it in my country anywhere, so no Alphacool, but everything else is ok
