I7 4770k temperatures
Hello,so i just wanted to know if my temps were ok. I am at 65-74C on prime95 load and around 25-30C idle. The cooler i'm using is not the greatest so I wasn't expecting great numbers but I just wanted to find out if these temps are ok? This is my first time building a PC so im worried I may have done something wrong.
I7 4770k, stock clocks, using a h60 2013 edition.
Thanks, I would really appreciate any feedback!
Stop using Prime95. Get AIDA64 and run the stability test. Otherwise those temperatures are fine. Every time you use Prime95 for stress testing you are damaging your CPU, be aware of that.
:O I wasnt aware that prime95 was bad for your system. Whats the difference between AIDA64 and Prime95.
(sorry if thats a noobish question)
AIDA64 is a proceedural test that tests each instruction set on the CPU die, the FPU, and the Cache but it does it in a way that does not overload the processor thermally. Prime95 loads the CPU die, the FPU and the Cache all at once far exceeding the engineered limits for its thermal load for a given modern CPU.
Oh ok, thanks. Also is there a reason that when i tested my pc this morning (About 20 hours after I built it.) my temps seem lower? This is after about 10 minutes of prime95.
(Also do i have room for a safe overclock? If so what speed? (I am extremely new to all this stuff.)
Cheap thermal paste takes time to cure, usually 24 hours. With an H60 you should be fine for a light overclock up to 4.0-4.2 GHz. I wouldn't recommend going any higher than that with the H60 because it doesn't provide enough thermal displacement to accommodate a 4.4 or higher overclock.
Also before you start overclocking pull back your stock voltage on the CPU core till it wont boot then bring it back up a hair from where it wouldnt boot. This will improve the thermal efficiency of your overclocking results as you can use less voltage to achieve a certain overclock.
Thanks, ill try that. I am new to all this though, do you know of any good guides for overclocking haswell?
J.J. from Asus did a really good one on the teksyndicate youtube channel. I would start with that one first as most UEFI bios these days are laid out pretty similarly.
