i7 3770k H100i temps
Hey guys,
I am getting worried with my temperatures on my i7 @ 4.2GHz @ 1.35V.
At idle I am getting 40 degrees average in 27 degrees room with my h100i on quiet mode with front fans on low (CM stryker). GPU is 44 degrees on idle but that is supposed to be higher anyway.
Is this normal?
Yes its normal, 3770k runs hot. Also notice that fans are not 100% all the time - if they were it would be lower.
At idle I'm getting 36'C with enermax liqtech 120x
Like to keep things as quiet as possible though.
Good to know.
