I understand that the fps you get would be different but if you used an i5 core against and i7 core, would you gain a lot of fps, or would the difference be small like 5 fps or so. If I bare get any gains in performance between an i5 and i7, when the i7 is easily $100 more, then It seems reasonable to just buy an i5 core and save that money.
Also, does the model of i5 and i7 of a 3rd gen matter, or is the difference in performance still small?
Thanks!!
You wouldn't gain more than 3 fps in any modern title because most game engines aren't made to use more than 4 threads.
You would get a I7 for productivity or rendering because editing and productivity is more optimized for more threads.
Actually, there isn't a performance difference. The i7 is exactly the same as an i5. But the i7 is better for multi-threaded workloads because it has hyper threading.
The performance difference between the two chips in gaming is either nil or within the margin of error. It isn't unusual for an i5 to beat an i7 in a particular game by 1FPS.
Get the i5 for gaming. i7 for heavy productivity.
Ohhhhhhh I see, well I don't do any video editing and I rarely use corel painter or photoshop, so its for commercial use and gaming with Diablo or starcraft. Solid then, I don't need an i7!
Thanks guys!!!
