Hi folks.
Im getting a new build, so far its looking good. Now i have to pick the right cooler, i was going for hyper 212 but i found that cryorig h7 was better for a small premium. What cooler would you recommend to oc an i5 6600k? My budget is very limited but i could spend a bit more than 35 bucks if needed.
Looking forward to hearing from you
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($227 )
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.99 @ Newegg)
Motherboard: Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard ($0 @ Newegg COMBO)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($75.99 @ Newegg)
Storage: PNY CS2211 480GB 2.5" Solid State Drive ($139.99 @ Best Buy)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($71.09 @ SuperBiiz
