what would be better for streaming the Intel Core i5 4670K or the AMD FX 8350?
i think i will overclock in the future with the cooler master hyper 212 evo
FX8350 will be better for streaming, because it has more physical cores. It happens to be the better overclocking chip, too.
saying that i take it the fx 8350 would be better for streaming then the i5 3570k?
thanks
Both i5 have the same number of cores, so the 8350 would be the better multi-tasking CPU.
ok just making sure thanks for he help :)
No worries.
well you can't overclock on the EVO on haswell because haswell will melt the sun but you can combo the 4670K with a Asus Mobo and get 150 off, granted its a 150$ mobo but its also a 150$ mobo so that's good
+1, the hyper 212 evo is enough for a mild overclock on the FX-8350, and is hugely insufficient for overclocking a haswell chip. Also, streaming on the FX-8350 with an overclock will still perform better than on the haswell. The haswell chips don't have a lot of realistic overclocking headroom, unless you want to spend at least 500 USD on a cooling solution. That makes them not faster at all than sandy bridge or ivy bridge, because sandy bridge was very overclockable, ivy bridge was less overclockable, and haswell is even less overclockable, and for people that overclock with off-the-shelf cooling solutions, all three generations will perform exactly the same from a net experience point of view. The FX-8350 still gets really hot with extreme overclocks, but most chips do 4.5 GHz constant with a pretty standard cooler on most motherboards, and AMD stocks to their socket, so you still have an upgrade path if your motherboard has a robust power delivery section. Intel chips do have greater bandwidth, but they also can't push memory as fast within the same budget as AMD chips, so again, if you overclock, the net result in terms of experience is pretty much the same, with the exception of the better scaling of AMD processors because of the extra cores. Once you overclock manually, and disable the cool 'n quiet turbo function, your AMD processor can keep all cores going and will not disable cores but offer constant performance on all cores, if your cooling solution can keep up that is, because it does get hot at that point, but nothing a decent off-the-shelf cooler can't handle. A haswell chip with an off-the-shelf cooler will sooner or later start to throttle because it gets so hot.
FX8350 will destroy the i5 in streaming ☺ i think thats enough said, its a much closer call to the i7.( it can probably also beat the i7 in streaming) and the i7 cost $150 more then the FX8350 The FX8350 is cheaper then the i5. So thats realy the best bang for buck. the money you saving you can trow in a good cooling solution, or a better gpu.
for streaming, you really want that multi-thread performance. 4 threads isn't gonna handle it as well as the AMD in most games. i've personally thested that the 8350 and the ivy i7 are pretty much equal in terms of streaming performance. and as far as your i5 option goes, unfortunately, haswell chips melt under load, which is why i switched back to ivy.
