I5- 4670k Overclocked itself to 4.1 ghz?
So recently I have been planning on trying to oc my i5- 4670k . So before going out and buying a larger heat sink I decided to bench mark my cpu with stock clock and stock cooler with prime 95. What I found first is my cpu hit around 90-100 Celsius. When it reached that I got scared and killed prime 95.
What I found was both cpuz and realtemp both say my core speed is around 4100mhz. Thus from what I understand 4.1ghz. So either I am reading something incorrectly or my cpu is running at 4.1ghz without me realizing it. I never went into the bios to change the clocks so I am confused as fuck.
Link : http://imgur.com/fNP27zI
parts: I5-4670k
Asus Z87plus
Corsair 2133mhz ram 2x4gb
gtx 560
Can anyone help me out?
Either you overclocked it and forgot or the motherboard bios/software did it for you at some point. Just go into the BIOS and drop down the multiplier til you get your cooler.
There is software included in ASUS AI suite that auto overclocks. I tried it on a system with a i5 3570k and it overclocked to 4.2. I would guess thats what happened.
Yep, I went into the bios and found that the asus mobo set the max turbo feq, to 4.2 ghz.
