Hi, I have about £350 to spend on a motherboard and processor, so do I get an i7 4770k and a cheaper motherboard something like a Asus Z87-plus/pro or msi Z87 G45/65 or go for an i5 4670k and a more expensive motherboard like the asus Z87 sabretooth or asus maximus VI hero/formula. If any other ideas please share, but I do wish to stick with an intel processor.
Well, it really depends on what you want to do. If you are just gaming and not as 1440p then you'll prob be just fine with the i5. You really don't wanna go cheap on the mobo.
I use a 1080p 3D tv and only light gaming ie dayZ/COD/minecraft and GTA IV , but my pc at the moment is used for all my media like blu-ray films/music and streaming movies too. I like to furture proof my pc, I am still using my pc i build over 4-5 years ago with a few minor upgrades like an SSD and graphics card.
They is so much choice in motherboards, asus alone have about 10 and then the is the other brands too. thanks alot for your help I think I will be going with the asus Z87 pro.
I did look at the AMD FX8350 black edition and when I saw it was 8 cores at that price I nearly wet myself, but when I started to look at the motherboards I could not find any with pcie 3.0 so its intel for me.
I don't think GPUs actually fully uses the full bandwidth on PCIe x16 2.0. I also faintly remember that AMD stated that Crossfiring on Gen 2 slots with R9 290Xs didn't see any noticeable performance impacts.
I can't think of anything that requires the full bandwidth of PCIe 3.0. And the Intel i5 4670K and FX-8350 are about the same in terms of performance. One's just better with single-threaded application and one is better with multi-threaded applications(4 cores vs 8 cores, kinda obvious)
I also am not sure about the GPU using the full bandwidth on PCIe x16 2.0, but the new nvidia GPU cards are PCIe gen 3, I just trying to build a pc that will be some what future proof, so I would rather buy a motherboard that has gen 3 PCIe that PCIe gen 2,
