i5 4670k or 8350 build
Alright, So I build an Intel build and an AMD build and I was wondering which one I should go with.
This rig will be used primarily for gaming and not much for anything else.
If it helps at all, I will probably be playing mostly counter strike go
anyways if you have any suggestions to improve these builds, I would greatly appreciate it.
Its basically the same build except different cpus
intel- http://pcpartpicker.com/p/38bcS
amd- http://pcpartpicker.com/p/387Ml
Both are very nice builds, but for gaming you could do slighly better on the AMD side. You could also add en FX8350 if you prefer. but both cpu´s are basicly the same, only the FX8350 is higher clocked out of the box. If you just bump up the cpu ratio on the FX8320 it will run the same speed.
http://pcpartpicker.com/p/38c90
Grtz Angel ☺
If I were you, and as you're only using it as a gaming machine I would go for the WD green 2TB rather than the 1TB black. Other than personal brand preference they're nice :)
greens die quicker from all the spin-up and spin-down
just from what i have been told
+1 on this...
here's an Intel option (i5/780) for $100ish more...
http://pcpartpicker.com/p/38lxE
Depending on what cpu intensive tasks you talk about. single threaded tasks ok, multi threaded tasks FX8350 all the way ☺
Greens die quicker and are slower than blacks. Wd black drives are the only drives I will use currently. When ever I try anything outher than blacks or reds they tend to die quickly. I have gone through so many greens, blues and barcuda's while my blacks are still runing after 6+ years.
Cpu intence games love to lap up the dingle core performance of intel. Games like battlefield and kirbal space program. But for most games the fx 8000 series are perfectlyfine. If your doing any sort of video editing and such grab the intel. The higher temp cap and lower clock speed is really worth it in terms of stabiloty in any sort of work station environment.
i5 is better in video editing then the FX8350... uhhhh? Do i miss something here? ☺
I'd imagine he meant a Xeon, which is a workstation processor...
yes that xeon is realy a nice chip indeed for productivity.
But its abit offtopic anyway, cause "op" talks about a gaming rig lol ☺
Just check the programs and stuff you'll be using.
If they can take advantage of the 8 cores of the FX-8350, get the 8350/8320 build.
If they like single core performance better, go with an Intel build.
Also, windows 8 is slightly better optimised for the AMD build and although games will eventually start to take advantage of the greater number of cores, they're not there yet. But mantle does look promising.
What do you plan the life cycle of this PC to be? Before you replace it.
