Hi i was just wondering if anyone had any overclocking tips for a bad haswell chip that overclocks like crap. If anyone knows a way to get to 4.4ghz that would be much appreciated :)
watch tutorial videos on youtube....
Use google to search for a guide on your particular motherboard and CPU combination. There isn't a universal guide for haswell chips. Each motherboard manufacturer has their own unique UEFI. You'll also want to make sure you have adequate cooling. Keep in mind, Haswell is a bad OCer to begin with, so don't expect too much without modifying your CPU (lapping, delidding, etc.) and/or running a custom loop.
moved to "overclocking" section, there are a couple of topics about the same question, just check them out.
grtz Angel ☺
