i5 4440 temps
so i haven't checked my temps for a while and when i recently did, i saw that under load, my cpu was at around 63 degrees celsius. i wanted to know if this is too hot and i needed to upgrade to an aftermarket cooler. when i first bought it, i figured i wouldn't have to as it is not unlocked and i would not be overclocking but im not aware of the comfortable temps and i have been experiencing some performance drops in demanding games and i wanted to know if it could be this.
thanks guys, this community is always very helpful:D
Its a locked CPU stock cooler will be fine unless you are nearing around 80 to 90C then I would be worried about getting the temps down.
63C under load for an intel cpu is totaly normal.
Intel haswell cpu´s run much hotter then AMD FX for that matter.
