i5 3570k overclocking
i currently have my i5 3570k set to 4.0 ghz and my voltage set to auto. however every so often when i boot my pc up it sais ''overclocking failed'' does anyone have an i5 3570k voltage to frequency correlation graph, if not what voltage does my core need to have 4.2 ghz and 4.4 ghz. Also if it makes any difference, im currently using integrated graphics (buying the amd 8970 next year)
Thanks in advance!
Start off with the stock voltage and slowly go up till it's stable. There's no real set amount... some cpus are better than others
