i5 3570k over clocking system advice
Im looking at over clocking the i5 3570k ivy to a max stable use of 4.2ghz.
i am just wondering if this system should be efficient enough todo so?
CPU: Intel i5-3570K
MOBO: AsRock Z77-Extreme6 Intel Z77
HDD: WD 3.5" Black 1TB HDD
HDD: Intel SSD-330 Series 120GB SATA3 SSD (os)
RAM:Skill Ripjaws-X 16G Kit(8Gx2)
OPTICAL:Samsung SATA 22x Black DVD RW
CASE: Thermaltake VO100A1W2N Commander MS-III Black USB3.0 Mid Tower Case (No PSU)
GPU:PowerColor AMD Radeon HD 7850 2GB GDDR5
COOLER:CoolerMaster Hyper 212 EVO CPU Cooler $35
PSU: A-Power M80 Plus 650W 80+ Bronze PSU $29
i am concerned about the PSU as i would like something 80+ and on a budget, and im not sure if 650W would be enough for this system.
Also would like to know if the CoolerMaster Hyper 212 EVO will be efficient enough to cool the i5-3570k CPU on a steady 4.2ghz clock?
Any other recommendations for these around the same price would be much appreciated.
Thanks
should be, someone else here as probably done it, but the hyper should be enough for 4.2
The CM Hyper has been enough for me to get to 4.8. The cooler is great. As for the PSU 650 is great. If you want a really nice 80+ PSU, go for the rosewill Capstone-650. If you want to crossfire and be safe, get the 750. This psu series has been taken apart and graded by multiple reviewers to be great. Here is one, http://www.techpowerup.com/reviews/Rosewill/CAPSTONE-750-M/10.html
Oh, and btw, if you're not willing to pay for an entirely new system, buy a quality PSU. When that thing dies out, your system dies out. A 30 dollar PSU will never be a good option for use on a machine meant to last any good amount of time.
Oh and I forgot to mention, higher clock speeds are achieved through a quality board (which you have) fed by stable power coming from the PSU. Then you keep the temps down with an aftermarket heatsink. Without the first two, you're screwed.
would it be possible to do all this with a quality 550w psu like " Corsair VS550 550W"?
You obviously plan to overclock, so I wouldn't push a 500 watt system requirement for the amd card with a 550watt psu. You always want to buy a little more than you need. And as for the psu, honestly any corsair, rosewill, seagate, or any other good, big company will be a good choice for PSU. If you have to, just use the i5's dedicated graphics until you can afford the graphics card that way you get the good PSU and are still able to use the computer for basically everything but playing games. Even then, the IGPU is actually pretty good. (Of course not 7850 good, but playable). A quality PSU that can support your hardware in terms of wattage and amperage is by far the most important part, gimping out on it will be your biggest mistake when it fails within due time.
So decided to go with the "Corsair VS550 550W Power Supply Units PSU". Hopefully it should have enough power to clock and have the quality to last.
should have spent that extra money on a 750 like people mentioned. started off with a 650 in conversation and ended up with a 550? lol
Just as a warning, don't expect that thing to last long when you're overclocking.
