i5 3570k or FX-8350
An already common question, but, after being strictly Intel, I've decided to make AMD an option for my new build. I'll be doing primarily gaming, and maybe a VERY small amount of editing in Adobe AE and Sony Vegas for school, so rendering performance doesn't matter much. What CPU would you recommend? Money is not a problem, though the 3770k is out of the question. I would absolutely be using the Asus Crosshair V Forumula mobo. I'm leaning towards the FX-8350 to save myself some a little money. Any answer would be much appreciated.
I'll be using the EVGA GeForce GTX 660ti Superclocked+ 3GB
the 8350 will be fine get a decent cooler and motherboad and overclock it a lot
I second this,I use to have the i5-3570k with a P8Z77 LK,I've switched it out with the FX-8350 and the Sabertooth 990FX,loving the Mobo and the CPU,extremely overclockable.
Using an H80i,4.8ghz OC,1.38volts, getting around 38~43 *C (At full load.)
Money isnt a problem but the 3770k is out of the window, why ?
Thanks for the answers guys, looks like the 8350 is for me, and @BeyondNight I Don't want, nor do I need a cpu that powerful, I'd rather get a decent cooler like the H100i.
ANY Intel "k" chip is well beyond good.
The 8350... IMO is not a bad chioce. They clock up extremely well but you better have a cooler on it.
http://www.youtube.com/watch?v=eu8Sekdb-IE watch for gaming
What you said. I was about to refer to this video myself. Logan had already confirmed what I had been thinking for several months(I have been planning my build for a while). Productivity, sometimes it wins, sometimes it doesn't, but with such a slaughter in gaming, the AMD is the way to go. You can buy a 8350 and a CM 212 EVO, for as much as a 3570k alone. The EVO is such a nice cooler you can OC pretty good with it and get performance even higher.
Slaughter?
AMD and intel CPU's go blow for blow with each other, only the i7 reigns supreme vs AMD's flagship...
No CPU slaughters either one.
IIRC there were a couple games in the video that the 8350 tied with the 3570k but the 8350 mostly won, and it absolutley murdered it in ArmA 2, which is a very CPU intense game due to it running unscripted AI.
