Currently I'm using my i5-3570k,no overclock, when i use prime95 for the small FFT stress test, the temps shoot up to 100~105 C, can anyone help me with this?
Note: I just switched out motherboards, from an MSI Z77-G41 to an Asus P8Z77-V LK, I also applied more TIM,I used the "pea method".
Sadly,yes. I plan on getting the Noctua D14 or something like it soon. However, before I swapped out my Mobo and TIM, I was running a 4.2 OC at 70~80 degrees C,why did it shoot up so dam much without an overclock on it?
It's on stock voltage,case airflow is good,ambient temp is around 15~20*C, this happened ever since I replaced the mobo,when I was using the MSI z77-G41 it was running great at 4.2 OC,stock fan,stock TIM, now that I've changed the Mobo and TIM the temps are absurd.
That's really strange, it must the mobo's power delivery cause there's no explanation to why your cpu would just do that. Have you contacted Asus about this?
No,it was only yesterday that I switched out the board, if anything, I can probably go back to MicroCenter and switch it out.
If I were to switch it out,should I get the Asrock Extreme 4 or the MSI again, I can get the MSI for ~$40,the Asrock would be about the same price as the Asus,around $90~$100.
I would sugest re-applying your thermal paste, if you're not doing any OC'ing and a mobo switch is the only variable, i would just redo it just to see what happens
I've heard nothing but good reviews on MSI boards so I would go with that. Personally I'm getting a Gigabyte board because they make really good quality stuff. ASRocks are basically downgraded Asus mobo's. I've heard the build quality isn't that great on them either but it should last you.
