I have my i5 3570k at 4.4ghz at 1.23v on a hyper 212 with prolimitech pk1 compound is 67c max temp after 20 hours of prime 95 and occt normal? It seems low compared to others
so, what's the metter? XD
Sounds pretty good to me, i get to 60c+ on a 3570k @ 4.2Ghz with a Hyper 212 Evo
erm.. matter
Those temps are good for a 212. Great voltage, good temps - you have a good chip :)
Ya idk if they fixed the original problem of the ivy bridges running hot like when they came out but all the videos I found were old and ran much hotter then mine. Although the ameint temp is low in my basement about 18 to 21 c
I am going to be attempting to hit 5.0gHz on my i7 3770k later today. I had to RMA my motherboard (Maximus V Formula), and the new one finally came. I had 4.6gHz @ 1.334V, but I had never tried lowering it. I used Turbo-V-Evo (an Asus app) to OC initially, and it worked, but I want to hit 5.0 @ 1.38V. I will post some screens and benches if I do :)
Sweet love to see it. I don't have the cooling or good enough motherboard to do any extreme overclocking but good luck.
I am using a Phanteks PH-TC14PE with Arctic Silver 5 compound. I was idling at 29 degrees with 4.6gHz, and maxing at 69 under IntelBurnTest. That is using the stock fans that Phanteks provided. I highly recommend the PH-TC14PE for air overclocking, at extreme leves, at least :)
