i5-3470 Buid. Need Opinions. Tight Budget
I'm getting ready to order the parts so i would like any suggestions or opinions on this buid thank you.
http://pcpartpicker.com/p/ugCq
  • Lose the 1866 memory, go to the 1600 unless you are using the IGPU, which you are not. and I doubt it will be benefitial due to your motheroard.
  • Spend the saved $5-10 on a better psu.
Yes, apart from that, it will work.
Can someone suggest a cheaper motherboard and get me a better psu.
