i5-3350P
Is the Intel® Core™ i5-3350P a good cpu or should i buy something else?
for that price get the AMD FX-8320
and with non K intel CPUs you cant overclock them
Ok, but just wanna know is it a good CPU?
At stock, yes. The disabled iGPU allows for a lower price tag, so if you aren't overclocking and a gamer, it's one of the best bangs for the buck, especially for Intel.
