I have decided to go with a core i3-3220 for my my first gaming build. Which motherboard is best for this and my GTX 560? And should I plan on OC my 560? Help..thanks.
You can probably get an average Asus board for about $100 using the z-77 chipset, you don't really need anything too fancy for that CPU and card.
If you're expecting a real performance boost I wouldn't rely on overclocking your card. If you're just going for a little extra you might as well give it a go.
