I don't know shit about mining, nor about miners. I know CGMiner and MacMiner, I know roughly how to use litecoinpool, and I know roughly how the chain works. But I know fuckall anything else.
I want to mine with my 580 I think. I have a nice big 8GB unit and having some cryptocurrency spare would be nice. I at one point had 2 whole bitcoin that someone gave me off IRC but I have lost it somewhere. Oh well lol.
That's what I was thinking, which currency are you thinking of mining? If etherum, follow the guidelines above If Bitcoin here, guy explains how to setup, and if you dislike the voice everything is in the description
Well so far I'm downloading the last 3 months of ethereum crap onto my laptop before I can make my wallet and mine. That'll be done sometime mid-day tomorrow.
The shit part is I'm probably going to make a backup offline wallet on my netbook to dump ETH into when I have this all going again.
If everything matches, open the config.txt file and add the following commands
-epool eth-eu1.nanopool.org:9999 // sets up the pool to mine for
-ewal 0xXXXXXXXXXXXXXXXXXXXX // this is your primary etherum wallet, make sure to replace the 0xXXXXX with your wallet number
-epsw x // I believe this is what shows up in your nanopool profile as worker X
-dpool stratum+tcp://sia-eu1.nanopool.org:7777 // I believe this is also part of the mining pool operation
-dcoin sc // not sure just followed the config from the thread
-dwal 0xXXXXXXXXXXXXXXXXXX // this is your backup/secondary wallet
-dpsw x // your name that shows up as secondary wallet
https://bitcointalk.org/index.php?topic=1433925.msg16395925#msg16395925
some one had a similar issue where the system had gpus but the miner did not detect it
now to find the solution to that
Yeah. I think I'll get back on arch so all my multimedia stuff works first, then figure out ethminer. Claymores just does not work correctly, and there has to be a reason for it. I'll fuck around with it later but its not worth my time to keep running into the wall, especially when I have to start wock on benching my 580 fully now that kernel 4.12 is out.
