Hi i would like some help regarding cable sleeving i dont know where to start im going to be using a cheap psu to learn how to do it so if i fail it wont be the end of the world any help where to start
http://www.youtube.com/user/lutro0
yeah you can buy $5 PSUs at Goodwill thrift shops for the first couple I would think you will have the hang of it after that
here's a detailed tutorial from nvidia
https://www.youtube.com/watch?v=dcsP2S0l9Ps.
But it does require modular PSU's but hey, you can always just improvise.
+1 awesome tutorial ... teach you to sleeve like a pro <<<===================================>>>
Tanks guys for the help my current psu is semi modular so i have some extra cable to try on
unplug the psu and turn it to the on position. Let is leak for 20 minutes before you open it up. Its not easy to shock yourself but it is posible especially if you don't have a bleed which im not sure is even legal in the usa anymore I think it has to bleed 50 volts a minute. Take this precaution getting shocked is annoying :D
