I think my build is almost done just need feedback
my build
http://pcpartpicker.com/p/25fzv
thanks for any feedback!
Your ram is a little overkill. The 1600mhz version of your RAM kit is less expensive and perfect for gaming. With the extra money saved you can get a 7950
http://pcpartpicker.com/p/25h1H
Otherwise nice build
+1.  Higher clocked memory doesn't matter in a gaming build, unless you're running integrated graphics.
I ordered that card at $210 - MIR(20).  It's been out of stock every day since then.  If you can snatch it up at that price, it'll be one hell of a deal.
http://pcpartpicker.com/p/25gZH
im happy with this
change the cpu to FX6300 its worth it, for all day use. vishera has some performance boost in single threaded applications over zambezi.
If I remember correctly, he got his CPU for free.  Therefore he's using it.
ah okay i did not read that anywhere, but if so, then my post can be ignored. ☺
yeah my friend gave me the cpu :p
