I think I bricked my GS4
Ok guys so I think I bricked my Samsung Galaxy S4 (At&t) trying to root and rom it. The screen it is on right now says in big letters Downloading... Do not turn off target. On the top left it says Could not do normal boot Odin Mode. Oh yea there is a big android logo too. So what is the problem and what is the solution. Also, I wanted to say that im running the latest firmware which I think is MF3, and the Android version is 4.2.2. The phone boots directly into this screen even when I pull the battery.
Thanks for the Help.
Looks like it is stuck in download mode. If it is stuck in download mode and you can't get out of it you might just have to flash something in odin to the phone to get it to reboot normally. Install your phones drivers on your PC and boot it into download mode and see if your PC will recognize it in odin. If you don't have odin you can download it here http://www.android.gs/download-odin-3-07/
My gs4 is bricked, but i'm on Verizon. If you go to at&t they will say you broke your warranty and to go fuck yourself.
Use ODIN mode to flash the stock firmware. Here is an archive, find your EXACT model number and read carefully...
http://rwilco12.com/downloads.php?dir=Files/Devices/
