I need validation over my plan of my first pc.
Hey, guys, are the case and other components compatible with each other? Is there any issue?
This is just my opinion, and assuming this is for gaming.
PCPartPicker Part List: Part List - AMD Ryzen 7 5800XT, Radeon RX 7600, Cooler Master MasterBox Q300L MicroATX Mini Tower - PCPartPicker
CPU: AMD Ryzen 7 5800XT 3.8 GHz 8-Core Processor ($159.99 @ Amazon)
Slightly better, slightly more expensive
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler ($29.99 @ Amazon)
Not bad, not great, it works.
Motherboard: MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard ($89.99 @ Amazon)
Matched the price of your MB choice
Memory: Patriot Viper Steel 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($48.99 @ Amazon)
I use this RAM, no issues for me
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($59.79 @ Amazon)
Slightly cheaper, negligible performance difference
Storage: Western Digital Blue 2 TB 3.5" 7200 RPM Internal Hard Drive ($64.98 @ Amazon)
Slightly cheaper, I’ve had better longevity with WD than seagate
Video Card: XFX Speedster SWFT 210 Core Radeon RX 7600 8 GB Video Card ($289.99 @ Amazon)
Exact same performance, significantly cheaper
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case ($39.99 @ Amazon)
Nothing special, it works
Power Supply: Cooler Master XG750 Plus 750 W 80+ Platinum Certified Fully Modular ATX Power Supply ($99.99 @ Amazon)
It works.
You do not need an ethernet NIC, the MB from both my list and yours come with gigabit LAN ports.
Do not buy a windows key from microsoft, plenty of third party sellers buy in bulk and resell for $15. Also, get Pro, not Home. Also, Linux, not for everybody, but I do recommend it.
Total: $883.70
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2025-03-13 18:53 EDT-0400
Honestly most of the changes I made are just personal preference. The biggest take away here is that the AMD graphics cards are a much better value. Don’t pay the nGreedia tax.
Cmon man, kindly do you due diligence and post the whole spec here instead of simply posting a link. Don’t underestimate the laziness if people and you’d get more engagement/replies.
The Masterbox Q300L case has bad airflow. For a 600W system it is ok but will definitely struggle with a 850W+ system.
The LGA1700 and AM4 are both dead end platforms that are close to reach EOL. They still work, and you can definitely game on the PC for a few years forward, but might not be the best cost-efficient choice. Then again if that is all you have…
The H610 is a mistake, plain and simple. AMDs low-budget MoBos still allow for some overclocking and basic gaming features, the H610 does not even support XMP (memory overclock), so you are stuck at default timings of… 2666 MT/s if I remember correctly?
The 4060 is currently one of the bigger traps in the market, low budget you should opt for the more performant AMD cards; they are cheaper and provide more FPS, and Raytracing is still a bit weak in the budget category.
A 2TB Hard drive when you can get a 2TB SSD for just like, $40 more? Why?
Don’t ever pay for Windows 11 Home - it works but when you can get Windows 11 Pro for $30 from sites like URCDKeys or CDKeyOffer or less if you use a promo code from tech tubers it’s just stupid. Pro is better in every way.
So, with that in mind, I would shift around the build priorities slightly. This is roughly the same budget. The drawbacks are that the GPU is slightly less powerful (but $100 cheaper), no RGB in PSU, and you only have 2TB of storage instead of 1TB+2TB.
The advantages: Faster CPU on the Zen 4 architecture, newer platform with faster memory, fast storage everywhere, can be upgraded to at least a Zen 6 architecture CPU (with 90+% certainty), good airflow in case, 100W more on PSU, overclockable and draws little power. The stock cooler is adequate for the task, but can be replaced by, say, a Phantom Assassin.
Type Item Price
CPU AMD Ryzen 7 7700 $265.00
Motherboard Gigabyte B650M AORUS ELITE AX $179.99
Memory TEAMGROUP T-Create Expert 2x16 GB DDR5-6000 CL30 $89.99
Storage Western Digital WD_Black SN850X 2 TB M.2-2280 PCIe 4.0 $147.00
Video Card PowerColor Fighter Radeon RX 7600 $269.99
Case Fractal Design Focus 2 $79.98
Power Supply Thermaltake Toughpower GF1 (2024) 850 W 80+ Gold Fully Modular $94.99
Operating System Windows 11 Pro $23.17
Total $1150.11
For GPU, I would like to recommend a 7600 XT, but tariffs have ruined the market for now. You basically have two options, go cheap and weather the storm, or sell a kidney (in the methaphorical sense :grin:) and go big. This is current market:
GPU Price VRAM Performance Rel. Cost-Per-Frame
Radeon RX 6600 $199.99 8GB 84% 88%
Radeon RX 7600 $269.99 8GB 100% 100%
GeForce 4060 $339.99 8GB 113% 112%
Arc B580 $365.00 12GB 110% 123%
Radeon RX 7600 XT $462.73 16GB 103% 166%
Radeon RX 7800 XT $642.91 16GB 201% 142%
GeForce 5070 $699.99 12GB 229% 113%
Radeon RX 9070 XT $939.99 16GB 210% 166%
GeForce 5070 Ti $939.99 16GB 255% 136%
GeForce 4070 Super $948.73 12GB 206% 170%
Performance is relative to the chosen 7600 and should be taken with a grain of salt, for instance some games the 7800 XT beats the 4070 Super and right now the better performance of Nvidia raytracing skews things in favor of Nvidia on the performance side. If you want the full story, watch reviews. If we remove Raytracing numbers we have maybe a 10% uplift for the Radeon cards.
The Relative Cost Per Frame means, how much more you are paying per frame compared to the recommended 7600. A higher number means worse cost efficiency and is just meant as a simple, but imperfect way to show the relative value of a card. Ballpark numbers here.
The case, as much as i like it, is really bad.
The holes are made such, that they block a lot of the air, and the filters block the rest.
If you want a good matx case with the option of becoming full atx i would suggest the LianLi 011 air mini.
It may be a bit more expensive, but its great in everything it does. I have one for a year or two now, I haven’t tested it with a mechanical HDD, so I can’t vouch for vibration or whatever, but other than that the airflow is great and its really solidly built.
All you need is a couple extra fans to help out and you are set.
PS: welcome to the forum.
Wertigon accidentally listed the case twice, so knock $80 off of his total price. His suggested build allows for a really solid cpu upgrade in a few years as well. The motherboards that OP and I both listed would, as wertigon said, lock you into a dead generation with no upgrade path other than a complete rebuild.
First of all @Kriegolus -
iu
Now for your rig – Playing Devils advocate, regards you you’re dead set on Intel 1700
12600KF – It’ll pack a healthy punch.
CM Hyper 212 – It’s been around, for a excessively long time-- Wouldn’t exactly trust, on newer HW
And the i5K, can still get toasty… Will get back, on talking Alternate(s)
Mainboard – Automatic NO-Go [That one is made for basic officey / locked builds]
Swap over for a Z690, to leverage full use of the CPU and memory [DDR4 still an option]
RAM – Fine with [can go higher speed, if you want]
SSD/HDD – Fine with choices
Strong Optional – Add SSD for Linux OS [aka, Dual Booting]
OS – IF need for Window$, get the Pro [+ can get bulk keys, for cheep ex. CDKeyOffer]
PSU – Fine with choice
Addtl NIC – Not a necessity, since Mainboards typically have embed 1GBit default
GPU – I thoroughly abhor its existence, “.”
Alternate GPUs – RX7600 / RX7700XT
Alternate [older] GPUs – RTX3060Tie [outperforms the 4060], RX6750XT (or +), RTX3070 (or +)
Case – It is a bit of a heat trap, due to poor ventilation [sheet metal isn’t near porous enough]
Alternate Case – Lian Li 011 Mini Air [+ comes with some fans on]
011 Mini Air can comfortably handle ATX mainboards as well [Know from experience]
Back to Heatsink – We got more vertical clearance AND more breathing room
Alternate(s) – Sycthe Fuma 3 / Thermalright Assassin King 120 / beQuiet! Pure Rock Pro 3
Oi U…
Y U having my case, but black?
WHUT U Mean? Had it fohh a while
I have the same case in white…
Its delightfully good.
The only thing missing is a mechanical fan controller, but with all case fans installed and running at barely audible speed they keep everything cool and quiet.
