Hello guys,
I've put together a gaming PC, and I need your opinion. Here's the list of components: http://pcpartpicker.com/p/N5zE . I couldn't find the PSU I'm about to get, but I did find it on amazon. I need to know if it's any good (it's a lite version but it's really cheap where I'm going to buy it comparing to the others). PSU: http://www.amazon.com/GX-Lite-600W-Power-supply-RS600-ACABL3-EU/dp/B006E17BG0/ref=sr_1_2?ie=UTF8&qid=1364591494&sr=8-2&keywords=Cooler+Master+GX-Lite+600W . Also, are there things I can save some money on? Since I'm really at my max at the moment. The graphics card I chose is like 30 bucks more than the cheapest available, and it seems really good with the 3 fans, or do would this be better: http://www.amazon.com/Sapphire-Technology-11196-19-20G-VGA-AMD7950-3072A/dp/B00BBKO65S/ref=sr_1_1?ie=UTF8&qid=1364592169&sr=8-1&keywords=4895106266063 (it's the 30 bucks cheaper one, it's not that expensive where I'm going to buy it). I'm very sure about getting the FX-8350 so you don't need to convince me to get an i5-3570k ;). Is the motherboard I chose okay? Last thing: I picked a zalman case, you get 4 fans with it, it looks awesome and it's pretty cheap, but I don't know whether my CPU cooler fits (I couldn't find it on the site). If you guys could help me out, that would be awesome! Thanks :)
