I need some decent cheap thermal pads for ram
I'd rather not spend for the best stuff, Has anyone found some that do the job for cheap?
I need pads as the ic creates a 1mm (i think) gap on the ECC ram with the sink
Or I have plenty of tubes of stuff around, could I try them or will it mess up?
8GB DDR2 ECC ram modules run hot
I found my answer, Phobya or gtfo
