I have an E-Machines computer, the model number is W3611, i believe its a 2006 computer? It was a hand-me-down from an old friend years ago. I had taken it apart, out of curiousity, beacause it crashed. i have placed all the wires back correctly EXCEPT the led, on/off switch, and usb. i cannot figure out how to reconnect correctly.
I am working on saving money for a new build from scratch but i would like for this one to work until then. any suggestions?
your front panal headers are at "O" or "N" trial and error. you can yous a key or copper penny to jump the pc find the 2 pins that turn the pc on and connect the on off switch to it. if you cant fix it that way http://www.geeks.com/details.asp?invtid=DG41CN-PB&cat=MBB or new psu but i would not put any money into this pc because its a p4. I could recommend some very nice thermite to get things working again. (ha ha physic joke)
Akira pretty much hit is spot on, if you still need help, try taking a picture of your motherboard and post it and ill circle which pins to connect it too.
This is the correct MOBO and i have been switching prongs around those areas and still nothing. maybe a more descriptive diagram or something? i appreciate it alot
thats the best pick can you give a close up picture yo are looking
you see it says +PW- that one is the power switch try to locate this on your mb if you can upload a picture of the pins on your mb i can help point them out did you try using a key or penny to trip the mb power?
ok so i have managed to get the power and led going and what not... now im stuck at a menu about raid volumes, physical disks...HDD stuff...both of my HDDs are non raid. it says to press <CTRL-I> to enter config utility...
my keyboard will not allow me to do anything,and it is powered on
