I need info about these WIFI AP's
i need to know some things about these WIFI AP’s
does the tp-link AX1800 WiFi 6 Wireless Dual Band ap , engenius EWS357AP Wi-Fi 6 2×2 11ax , an the
engenius EWS330AP
have a power range control option for the signal coverage like the TP-Link AC4000 Tri-Band WiFi
Router (Archer A20) does
so i can taper the signal coverage to just the home. for either individually or vi mesh set up i dont need the signal to exceed my home sqft of 1250ft my property lot size is only 0.27 Acres an have no
need for signal to cover the yard or well into the street an the neighbors yard an house i dont want or need that
also can any or all three of these AP’s disable or turn off the 2.4ghz antenna
as i have nothing that needs it an some gear in my home makes an or gets interference on 2.4ghz ?
